Repair information and guides for MacBook Pro models with 13" displays.
9756 Questions View all
MacBook Pro does not recognize my HDD
Since a week, I can't get my MacBook Pro to recognize my HDD. When I use the install dvd, i can't select my HDD and with Disk Utilities, i also can't see the HDD. I tried another new HDD but it didn't work also. Both drives work when I use it in an USB SATA external drive.
What part do I need to replace for my MBP?
Update
Just replaced the HDD cable but with no luck. It must be the logic board then. Thank you for your time guys!
Score 1
1 Comment
You mentioned this problem is still an issue on your other question, let's see if we can get some answers!!
by
Add a comment
Chosen Solution
Replacing the hard drive cable may solve your problem. Here's the one for the 2009 model: MacBook Pro 13" Unibody (Mid 2009-Mid 2010) Hard Drive Cable
MacBook Pro 13" Unibody (Mid 2009-Mid 2010) Hard Drive Cable Image
Product
$34.99
Score 4
5 Comments:
Thanks for answering.... Knew you would! Think we're sorting his other question. :-)
by
Just replaced the cable but with no luck. It must be the logic board then I think. Thank you for your advice!
by
This port normally doesn't just go out without some help. What happened?
by
According to the owner cola was spilled on it.
by
well, that might have something to do with it.
by
Add a comment
C Ata - did you have to replace the logic board? Is that the same as the motherboard ... if so how much was that?
Add a comment
Add your answer
[deleted] will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 3,257
