The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
116 Questions View all
How to tune mercedes W123 model. What should be the idle R.P.M., CO2
I have a mercedes W123 which is a carburetor model. After driving a short distance my car can stop dead. Or after driving, when I park the car for about 15 minutes, the car would not start. What is the problem?
2 Comments
@nsiemsen is the only regular on the site that might know this. This will alert him to your question.
by
@tongchee what exact model is your Mercedes? What have you checked?
by
Add a comment
Chosen Solution
W123 with Stromberg or Pierberg carburetor use 115 engine, 200, 220 and 230 model variants. US models have idle fuel shutoff solenoid for main mixture adjustment. Non-US models have 10 mm hex screw for main mixture adjustment. Both versions have a triangle shaped fuel-return diaphragm where the two fuel hoses connect to carburetor. This diaphragm eventually leaks and causes very rich mixture because fuel is sucked through the vacuum hose (located on bottom of carburetor). Difficult starting, blackened exhaust (unburned fuel) and poor mileage are typical symptoms of failed vacuum diaphragm. Complete flooding can occur as well, which may explain engine stopping after driving a while as well as not restarting when parked briefly. Blackened exhaust after warm restart indicates flooding, long cranking accompanied by stumbling and rough running for a few moments may indicate lack of fuel delivery. Three screws hold the triangle shaped diaphragm in place. Fuel starvation and insufficient delivery point to a weak fuel pump or air leaking into the suction line. Crank the engine with carburetor fuel delivery line disconnected, pointed into a container. Strong steady stream of fuel should be visible. If not, fuel pump and suction line need attention.
Score 2
Add a comment
Hi
My W123 200 1984 477 000km with a Pierburg 175 cd carburator idle at 850 rpm and i adjusted the co level at 2.0,im happywith the consuption and preformance.
Add a comment
Add your answer
tongchee will be eternally grateful.
Past 24 Hours: 8
Past 7 Days: 18
Past 30 Days: 43
All Time: 4,270
