MacBook Pro models with a 15" display
8258 Questions View all
LCD replacement screen does not light up
Hi.
I installed a new LCD screen on my MBP, and when I turn it on it barely (if at all) lights up. I can just barely make out the screen and see that I'm logged on. From what I can see everything else works fine, just the screen does not get bright.
Score 2
1 Comment
So update, it does light up, but if I move the laptop then the light shuts off again... so I have to shut off and turn back on computer in order to have the screen light up again.
by
Add a comment
Most Helpful Answer
Being able to see the desktop darkly usually indicates a bad inverter. In your case it sounds like a damaged inverter cable. I really can't tell without knowing EXACTLY which machine you have. Please list the last three letters of your serial number for identification.
Score 2
Add a comment
Hello,
I have a A1260 2.4 Ghz Macbook Pro that I bought new in June 2008. It was working again for a while, but this morning I picked it up with one hand and almost dropped it, but caught it before it fell, however it caused the light to go out again. Now if I move the screen up and down the backlight will turn off again... so I'm back to sqaure one.
Add a comment
Add your answer
burtonjp will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 5
All Time: 1,765
