Why does radio remain on after ignition shut off in 1999 Saab 9-3?
1999 saub 93 convertible: ignition turned off but radio remains on.
Yup, it's by design. It's so that you can keep listening even when the engine is turned off
My truck does the same thing--its a feature. +
That's not what I'm talking about it stays on but the volume doesn't work and you can't change the station
I suppose the radios power lead is directly wired to the battery current. Find a cable that is triggered by the ignition (e.g. the lightswitch) and wire it to that.
A piece of metal covering over the key hole has maybe been pushed inside the ignition. It causes the car to act as if something has been left on. It does not run the battery down but have to manually lock the doors.
The Saab has an ignition switch in the center section of the transmission/handbrake area. Over time, this gets dust into the mechanism and when the key is removed the ignition no longer pops up. This is a very common problem with Saabs, especially the 93 and 95.
You can try jiggling the key to pop it back out. If this does not work, you could also try blasting it with some compressed air and then applying some WD40. Usually that will fix the problem.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 10
All Time: 4,015
2 Comments
Does it turn off when you open the door? If so that's considered a feature so you can listen to the end of a song when you shut off the engine--my pickup does that. +
by rj713
So does my Caddy
by mayer
