Updated version of the Kindle Fire 7" tablet by Amazon with 1280x800 HD display. Released September 2012. Repairing this device is straightforward.
101 Questions View all
Why wont my kindle fire HD charge?
My kindle fire HD has been through alot. It has dropped in numerous amounts of puddles, It has been dropped on hard wood floor, tile, and concrete. But one day, it just wouldnt charge. I think something was attached to the battery to charge it, and it disconnected. Ive has this kindle for 2-3 years and I dont wanna lose it. What do I do?
Add a comment
1 Answer
Chosen Solution
@tcellitti ,TONEY, The battery, cable/charger or charge port may be faulty damaged. Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue also look in the port for any bent pins and straighten very carefully with a tooth pick. Try a different compatible charger/cord to see if that is the issue. If different compatible charger/cord does not fix and port looks/test good, the battery or connection could be bad, if able to clean battery connections and reconnect/install battery, still not charging battery probably faulty. If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide to get you inside the tablet to check the charge port, battery, loose/damaged components/connectios and will also post a link showing what is involved in repairing a mini USB attached to the board. If you get inside the Tablet and notice a lot of corrosion from water, I recommend you use the guide from the last link to try and clean up the all the connections,etc. while apart. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Good luck.
Kindle Fire HD Teardown
https://www.youtube.com/watch?v=dxqq_XJA...
Electronics Water Damage
Score 3
Add a comment
Add your answer
TONEY CELLITTI will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 11
All Time: 312
