The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
498 Questions View all
Could the drain pump be clogged?
Put a load of laundry in the machine filled up with water then nothing the 'green senser light is on I drained it manually it drained out very slowly so I was wondering if what's causing the machine not to start is it is plugged it drained all the water except a couple gallons I did the test on it and it did everything but left a couple gallons of water in it
Update (03/30/2017)
Locks look good it filled up with water all the way so I manually took the water out drain the water out and it came out very slowly like something was clocked in there would that stop it from wanting to run the central light stays on and just play Nothing Else and hear a humming sound thank you
Score 1
2 Comments
It is door lock assembly but the parts go to take a week to get here is there a way to bypass them so we can do the laundry
by
Add a comment
1 Answer
Chosen Solution
If your Kenmore 110 Series Washing Machine is not draining after a wash cycle, see the Kenmore 110 Series Washing Machine Won’t Drain problem page for possible causes and solutions.
This can be several things. Let's go with the cheap fixes first. Do you get an error code?
Unplug the machine for five minutes to allow it to reset.
Cause 1
Door Lock
The door lock assembly might be defective. Inspect the door lock for damage. If the door lock is damaged, replace it.
Cause 2
Door Latch
The door latch assembly might be defective. Inspect the door latch for damage. If the door latch is damaged, replace it.
Score 1
Add a comment
Add your answer
Eddie lynn will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 787
