1.83, 2, or 2.16 GHz Core Duo processor
281 Questions View all
Replacement Hard Drive Does Not Power Up
I bought a Seagate Momentus XT for my Macbook Pro. I installed it as per the detailed instructions, but it does not appear to be starting up. The Seagate has a spot for a power cable, which the original drive did not have. The Macbook does not have a power cable, so I'm not sure what to do. I bought this drive specifically because several people have said it worked fine in their Macbook, so perhaps I have a bad drive, but I'm not sure.
I put the original drive back in to confirm I did everything correctly and it started up fine.
Score -1
1 Comment
Have you talked to your sources who recommended this drive?
by
Add a comment
1 Answer
Chosen Solution
According to the writeup at Newegg.com it should work. Its designed to work in any SATA computer so I wonder if the power connection you see is for someone like me building computers and having a limited supply of SATA power ports to connect to a regular power connection. You would not want to connect both. Did you partition and format the drive before installing? Here is a link from Apple on installing--hope it helps.
http://support.apple.com/kb/HT3910?viewl...
Score 2
1 Comment:
you are correct, it has both power connections. He probably forgot to format the new drive.
by
Add a comment
Add your answer
Rich Cacace will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 3
All Time: 1,406
