2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Questions View all
screen broken- how to get a cheap replacement?
Hi all,
I have a macbook pro here with broken LCD. The apple repair shop was going to charge me 700 dollars to do the repair.
I'm confident I can install the screen myself, I'm just not sure if I should get just the panel, and if I should also get the cable from the computer to the panel, or if I should just get apple part number 661-4342 like they recommend, which is the full assembly that can be ordered from Apple.
thanks,
B
Score -1
Add a comment
Most Helpful Answer
You can get a used one here for $218: MacBook Pro 15" (Models A1226/A1260) LCD Panel
or a new one here for $295: http://www.dvwarehouse.com/Apple-LCD-Dis...
MacBook Pro 15" (Models A1226/A1260) LCD Panel Image
Product
$179.99
Score 1
2 Comments:
hi mayer
thanks for point me to the right links- i'm not sure if it is the LCD panel that is broken, or the cable going from the display to the LCD panel. is there an easy way to figure this out?
thanks!
b
by
Only if you have the spare parts. If the screen is broken, does it come on at all? If you see a desktop, forget the cable. Why would you suspect the cable when the screen is broken? Hook it up to an external monitor to see if all else is working.
by
Add a comment
If you want to troubleshoot the cable and screen separately, get a spare/new cable first (given the cheaper price I suppose) and you should be able to pinpoint the problem from there.
If you end up needing to buy a new screen instead, you can always resell the cable.
Maybe obvious, but my 2 cents nonetheless ;)
1 Comment:
This makes perfect sense and is a smart way of doing some troubleshooting. Great advise...:)
by
Add a comment
Info for UK users ...
I recently needed a new screen for my MBP. I had the nvidia graphics card problem last year which Apple replaced for me free of charge, but this time the screen had gone completely and it needed a new panel. Apple quoted me £370 for the replacement.
I did not want to undertake the replacement myself but I found a company in the UK who will do it for you. I can heartily recommend David at Mactuition near Bath:
http://www.macbookscreen.co.uk/Home.html
He replaced the screen for me for £199 plus £15 postage. I think his price has now increased to £229 plus postage though. I sent the MBP to him by post on Friday and it was back with me on Wednesday.
Having just upgraded the RAM and hard disk myself using the instructions provided here on ifixit, I might be tempted to do the replacement myself in future, but at the time I was nervous about doing what seemed such a large job. Plus the professional service from David was little more expensive than sourcing a new panel myself.
Add a comment
Add your answer
bert schiettecatte will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 5,409
