MacBook Pro models with a 15" display
8258 Questions View all
HDD Replacement Process for recovery
This website is great. I still have questions regarding this process. I am going to write what I think the steps are.
1. Use super duper to clone my current HD on an external HD. Also back up using time machine.
2. Replace my hard drive (using the instructions on ifxit)
3. Turn on my computer and then ???? not sure what to do next.
Thanks
Score -1
Add a comment
1 Answer
Chosen Solution
I recommend going in this order:
Get a replacement hard drive and a hard drive enclosure.
Next you have a couple options(Doesn't matter which option you go with):
A) Put the replacement hard drive in the external enclosure. Boot up your laptop and use Disk Utility to format the new drive, then use SuperDuper to clone your old hard drive to your new hard drive. Finally, take the new hard drive and follow the guide to put it in your laptop.
Or
B) Use the guide to put the new hard drive in your laptop and put your old hard drive in the external enclosure. Boot your laptop from the old hard drive and use Disk Utility to format the new drive. Then use SuperDuper to clone the old hard drive to the new hard drive.
Then you should be good to go. Hope that helps!
Also, check out our HD-Software Install Guide. Option 2 will go into detail about using SuperDuper to clone your old hard drive to your new hard drive.
Add a comment
Add your answer
btupp will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 1,076
