Screen Distorts and Freezes
My old iMac G5 crashes all the time and the display is throwing up all over itself.
It is not an OS related problem since I have done several clean installs. The real craziness is happening on the display with crazy lines and colors popping up everywhere. When I move a window over the artwork that has been generated, it erases all of the craziness until it happens again.
It also freezes many times a day. Not kernel panics. It just freezes up. Must then hold the power button until it powers off.
I'm thinking this is because the graphics card is shot and this is causing the freezes.
Score -1
Add a comment
1 Answer
Most Helpful Answer
This is happening due to the GPU chip overheating and having damaged the soldering connecting it to the logic board. Instal istat pro widget and monitor your temperatures and fan speeds. Make sure all your temp sensors are working and clean out all the dust from the heat sink. Clean your fans and make sure they are working properly. Inspect your capacitors and make sure they are not bulging or leaking. I would take out the hard drive and use it with an external enclosure otherwise it might get damaged if it is being used in high temps.
Honestly tho, once the GPU has been damaged then it will stay like that. The only thing you can do is prevent it from getting worse by reducing temperatures. You can fix the soldering by performing a reflow on the chip, it is hard but not impossible to do, I learned about this procedure here on ifixit when my imac had the same problem. Here is my old post:
video graphics and boot issues
Score 2
1 Comment:
+ not a bad answer. I really wouldn't worry about thew hard drive. For the definitive answer on this go to www.jimwarholic.com and hit the Apple link.
by
Add a comment
Add your answer
Gary will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,502
