0
Score
Avatar
timduffin
Asked
Fan constantly on at 6000RPM all the time
History
Dear all,
I recently replaced the logic board on my Mac, now I have this fan constantly on at 6000RPM all the time issue.
So I did an Apple hardware test using the installation disk that came with my Mac and got this cryptic error:
4SNS/1/40000000:Th2H-128.000
After some googleing I came across this:
Th2H Right Fin Stack Proximity Temp
My question is, is the Th2H Right Fin Stack Proximity Temp the Right Thermal Sesor, or does someone know what part the Right Fin Stack Proximity Temp refers to?
Thanks in advance.
Tim.
Edited by
Product Image
MacBook Pro 15" (Model A1260) Right Thermal Sensor
Make sure your computer's running cool — 1 available at 9.95 each.
Post Answer
3
Score
Avatar
dries
67
Answered
Accepted Answer
PermalinkHistory
Hi man
download this app http://www.macupdate.com/info.php/id/230...
Then from the terminal, type in the second line (4000):
/Applications/smcFanControl.app/Contents/Resources/smc -k F0Mx -w 60e0
(that's the default 6200 RPM)
/Applications/smcFanControl.app/Contents/Resources/smc -k F0Mx -w 3e80
(That's 4000 RPM Max)
You obviously gain a few degrees C when limiting to 4000, but at least your MBA shuts up.
Had the exact same problem, was so glad i found this
Edited by
Dries. That worked like a charm, though I'm still on the path of wanting to find out the true nature of the 'error code'. I'll report back here if I find anything. Thanks.
timduffin,
0
Score
Avatar
Roscoe P
Answered
PermalinkHistory
Dries, I have a question for you...
I have an iMac 7,1 2.4GHz C2D running Snow Leopard. The fans run on full speed continuously. I have had it checked out and it is diagnosed as “fails CPU temperature diagnostics – always over temp” In other words, as soon as the computer starts up, the fan(fan sensor) thinks the CPU is HOT and runs the fan full speed. I tried your second line as above, but i get this message in terminal “command not found”.
Is there something else I should enter at the terminal command line for my iMac? I’m desperate for help. It’s either find a solution or trash the iMac!
0
Score
Avatar
Carlos
Answered
PermalinkHistory
This worked for me too as I'm having the same problem. Wondering if you resolved it? You said you would post back.
Add Your Answer
