GE Profile Tri Temperature water dispenser will not heat water
Will not heat water, even though hot water switch is in on position (l). Water dispenser is plugged in. Instructions warned that hot water function would be destroyed if hot water tank ran dry. This never happened. Unit purchased Sept 2004. House fuse is not blown. (Electrical outlet functioning & green light on unit is "on") Checked to see if temperature limiter was tripped by setting hot switch to off (O) for five minutes, and then set to on (l) for 30 minutes. Red hot indicator light on front of unit does not turn on indicating heating cycle.
