Where I can find LCD pannel? model LM171W02
I have an iMAC G5 (EMC 2114) and the LCD pannel broke.
Where I can find a replacement pannel?
It appears this is the Intel Processor not a G5. The part number is 661-4020. You'll have to do a Google search. There are a lot of over priced units out there, so take your time.
Research +
had good luck using Google and finding a vendor with a reasonable price.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N.
Do what I did, buy a dead G5 from ebay or off gumtree. I have found the G5 imac screens can be put into the intel C2D imacs. The one's I got both had the LG philips screens LM171W02 but the intel lcd had a later production month and the letters on the end were different. The troubled lcd's had (TT) (A1) at the end. All you do is swap the support-carraige and the video cable and inverter from your intel lcd onto the G5 lcd. When I peeled back the foil from the G5 lcd which completely covers the G5 lcd back, it had the same part number quoted above and the video cable slot is in the same position on both lcd's so it is a simple swap. Ebay has regular dead G5's and they go for parts cheap. It is hit and miss though. I have got a couple, one was isight, that was dead all round, except for the inverter. Careful prying the inverter off the lcd support-carraige, the glue is strong and you don't want to crack the inverter board. Good luck.
Eu gostaria de saber se a tela de G5 serveria no iMac intel core duo 17 ambos de 17?
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 3,208
5 Comments
Apple iMac "Core 2 Duo" 2.0 17-Inch Specs
Identifiers: Late 2006 - MA590LL - iMac5,1 - A1208 - 2114
by mayer
If this appears incorrect, please give us the last three letters of your serial number (located on the bottom of your stand)
by mayer
by rafael raposo
Se os números das peças na parte de trás da tela (inferior esquerdo) são os mesmos, ou se sobre uma pesquisa para o número da peça original o outro número surge como compareable ou compatível, sim. Caso contrário, não
by originalmachead
Você escreveu uma pergunta no lugar de Respostas somente ... por favor, use o botão Adicionar Comentário.
by originalmachead
