Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Questions View all
iMac EMC 2015 fails to eject RAM
Pushing the white levers outward to pop out the RAM has now failed - the chips are still embedded in their respective slots.
I fear that repeated insertion and removal of the RAM has eroded the plastic which would eject the chips.
What should I do to remove and insert the RAM?
Add a comment
1 Answer
Chosen Solution
My question is why you are ejecting the RAM that much. And why do you feel you need to do it again?
To get it out get a friend with a small pair of needle nose pliers. While one of you pushes on the levers the other grasps just the edge of the where no cuicuits or chips a re and gentle pulls.
Then make a decision and put the correct RAM back in one last time and leave it alone.
Score 1
Add a comment
Add your answer
lkvee will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 73
