0
Score
Avatar
Akber Jesani
119
Asked
iPhone 4 wifi signal issues greyed out
History
I replaced the lcd and digitizer on an iphone 4 after successfully installing the front panel i tried to connect the phone to wifi and there is not wifi networks available. The wifi setting is disabled (grayed out) unable to make a selection for the wifi.
Any ideas or suggestions as to what may have caused this and what is the best remdy for this problem.
I have tried to reset the network settings but that did not help, my next attempt will be to update the firmware hoping that may resolve the issue, however i strongly feel that this may be a hardware issue.
where is the wifi antenna located in the iphone 4?
If anyone has has this similar problem please share your experience with me.
Edited by: Sterling Hirsh ( )
Post Answer
0
Score
Avatar
bushing
4.1k
Answered
PermalinkHistory
If Settings shows Wifi as grayed out ("No WiFi"), then the WiFi chip on the main board is bad and you will have to replace the whole main board.
0
Score
Avatar
pollytintop
39.3k
Answered
PermalinkHistory
according to the teardown for iphone4 "Apple has integrated the UMTS, GSM, GPS, Wi-Fi, and Bluetooth antennas into the stainless steel inner frame." the teardown also notes that there "are pressure contacts on the inner face of the rear panel which look like they are for an antenna"
it doesn't actually identify the wifi component
go back and clean the frame and inner rear panel-check for defects, scratches etc. it may not work, but it's worth a try.
Edited by: pollytintop ( )
there are all sorts of references to cleaning metal to metal contacts as oily residue may interfere with wireless function. I'd open the phone and clean clean clean
pollytintop,
0
Score
Avatar
luqman ahmad
Answered
PermalinkHistory
hi I reopened and found out the couple of screws were not in he right place as their are many screws of different sizes I just rearranged the screws according to the ifixit guide and it worked out perfectly.Thanks for your reply.
You rearranged the screws according to the ifixit guide? Where is this guide? I am looking for it all over and I can't seem to find it. Thank you.
Juan Mejia,
0
Score
Avatar
Krayzee
107
Answered
PermalinkHistory
if you have no wifi the gold antenna at the top is most likely damaged
try checking the gold antenna at the top of the board, it needs to be connected to the middle housing for the wifi to work, also the screws are important because they act and pathways for the circuit board
Krayzee,
0
Score
Avatar
Mishanya
Answered
PermalinkHistory
Good News Everyone! After I had spilled water on my device about a year before and I got the same problem: my wifi was greyed and bluetooth was not working either on my iPhone 4. I tried all possible solutions:
1. Airplane on, turn the iphone off, turn the iphone on, turn airplane off, and then wifi was supposed to start working. BUT not with my device(
2. Freezed it for 30 min in a plastic bag. BUT it was a time waste.
3. Then settings-general-reset network settings/all settings. BUT it didn't work.
4. Eventually I diassembled my iPhone 4, removed all 5 screws from wi-fi antenna (NB: pay special attention to 4.8 mm screw, as it is supposed to be the primary reason for wifi bad performance), cleaned all these screws and all metal-to-metal contact points on the connector cover with a de-greaser. Then reassembled it
AND WI-FI APPEARED!!!
Thanks to ifixit)
0
Score
Avatar
Karla
Answered
PermalinkHistory
I dropped my iphone 4 in water. It didnt even completely sumbmerge in it but not my wifi is grayed out and wont work. What do I do?
0
Score
Avatar
Aubrey
Answered
PermalinkHistory
Where is this screw your talking about? I know I have some missing
0
Score
Avatar
nathaniel
Answered
PermalinkHistory
on wifi antena on iphone 4 where does each screw go because i have 5 and they are diffrent sizes and im not sure wich one goes where please help asap thanks
0
Score
Avatar
Mikey w
Answered
PermalinkHistory
Not long off the phone to apple as my wifi was greyed out
And what they told me to do was add other user account on my laptop and try
Reinstalling latest update via iTunes and presto wifi back hope this helps others out there
Add Your Answer
