Repair guides and support for riding lawn tractors sold under the Murray brand name, currently owned by Briggs & Stratton.
140 Questions View all
still not starting gas is new
Gas getting to carburetor but still not starting gas is new and plugs and oil
Update (09/11/2016)
Murray select riding mower
Update (09/11/2016)
Dry Murray select model 42A707-2653-E1 yes I have spark and turns over put gas in carburetor it starts and dies out
Add a comment
Chosen Solution
Scott Irwin "put gas in carburetor it starts and dies out" sounds like a stuck needle valve or bad fuel solenoid. Take the carb off, clean it and check the float level and needle valve. Here is the parts manual for your engine Briggs & Stratton 42707. I also attached the service manual for the carburetion of your engine B&S Carburetion Carburetor overhaul kits are available at places like this and many others.
Score 2
Add a comment
Most Helpful Answer
Scott, trouble shooting small engine no start links below. Check the attached links,instruction and guides, Good luck
https://www.briggsandstratton.com/na/en_...
http://homeguides.sfgate.com/riding-lawn...
http://www.mtdparts.com/equipment/mtdpar...
Score 2
Add a comment
Add your answer
Scott Irwin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 256
