Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
104 Questions View all
Screen turns on then goes black but iMac is still on.
I have a problem with my iMac. Every time I turn it on the screen will turn on for about 2-5 seconds then it will go black. The Mac however will stay on and will on work if I connect it to a a monitor or tv.
Add a comment
1 Answer
The most likely cause is the backlight board. It'll go on for a couple seconds, then essentially get tired and turn off. If it truly is the backlight board, if you look really close right after the screen shuts off (like really super close, and possibly with a flashlight), you'll see a faint outline of the Apple symbol in the middle of the screen. It's an easy enough repair if you have a replacement and the right tools.
Other sources of your problem include the actual LCD, and the graphics card. It's harder to test those though unless you have another one you can put in to see if it fixes the issue.
Add a comment
Add your answer
Napoleon Sims will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 290
