Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
My internal display not working.screen, inverter, cables ok.
i have a black macbook 2.2 that suddenly went to a white screen while in use.. all i did was move the screen/tilt and it happened. still showed desktop on external monitor for a few minutes then external only showed extended desktop. have replaced the lvds cable, tried a working screen/inverter/lvds from another working mac: no avail. would the video card or another chip need to be reworked? swaped ram..nothing.. please help. thanks
Score -1
Add a comment
Most Helpful Answer
If the external monitor is working (I'm not sure what you mean by "extended desktop"), then there are only four things that can be fixed.
The Display Data Cable: MacBook Display Data Cable
The inverter: MacBook Display Inverter
Check to see if you can see the desktop by shining a flashlight on the screen at an angle.
The LCD: MacBook 13.3" Santa Rosa/Penryn Display Assembly
The Inverter Cable: Apple part # 922-8281: http://www.welovemacs.com/9228281.html
MacBook Display Inverter Image
Product
$14.99
MacBook 13.3" Santa Rosa/Penryn Display Assembly Image
Product
$299.99
MacBook Display Data Cable Image
Product
$19.99
Score 3
1 Comment:
Add a comment
Before replacing the LCD, you might try to reset your SMC. It may work for you if you have already replaced the inverter and inverter cable.
http://support.apple.com/kb/HT3964
Score 1
Add a comment
Add your answer
ALFIXN will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 8
All Time: 3,916
