1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
142 Questions View all
Question Closed
why do my usb ports dont work?
After a power surge overseas, my usb ports are not recognized by mouse or keyboard. The firewire port is also not recognized. It does boot up and I'm able to see everything.
Do I need to replace the logic board?
Thanks
Add a comment
Chosen Solution
Probably--the ports are soldered to the logic board. It is likely the power surge damaged a chip on the logic board. Before you give up on it try doing the usual resets to the PRAM and the PMU. You might get lucky. Ralph
Score 1
Add a comment
Another thing that's turned up on macintouch.com recently is resetting the firewire bus. You do this by disconnecting EVERYTHING from the computer, all cables, and the power. Let it sit for a while, like 5 minutes. Perhaps an hour or two wouldn't hurt. Then reconnect everything and see if there's any improvement.
Here's an Apple article on Firewire/USB problems: http://support.apple.com/kb/HT1317
That said, I have minis under my care with blown firewire ports, nonfunctioning ethernet ports--no bad USB ports yet, but I have seen it in the past on other computers. If none of these tips brings them back, then it usually means you need a new logic board.
Score 1
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 3,961
