2
Score
Avatar
Albert Castellana
25
Asked
Lateral hit, MBP shuts down from time to time.
History
Hi, I was carrying my MBP on a bag when it broke down and it fell down from 1m or so from the lateral corner where the hard drive is. There is a hole but everything works fine except for that it shuts down from time to time.
It may stay a day without shutting down, or it may close one time and another for a week.
Lately it's worse and i just can't use it any more.
When it shuts down it seems like it had no power source ( though it happens both with battery and without )
Does any one have any idea of what to do?
Thanks
Edited by
Post Answer
2
Score
Avatar
machead3
12k
Answered
PermalinkHistory
Could be
overheating, Or damage to HD
Boot from Systems disk, run->Tools->Disk Utility->Disk First Aid, repair disk.
Could be that the fall loosened or broke a thermal indicator, or the thermal paste.
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
Machead, thanks, I have tried the disk repair tool but that ended without any problem so the problem must be somewhere else. The computer shuts down either if it's cold or really hot, plugged, un-plugged or without battery. And I haven't seen any pattern that could tell me where the problem is except that it 'decides' to boot easily when i close the screen. Any other idea? Regards
Albert Castellana,
Please post this as an Update to your Question, or a comment to my Answer. Only Answers belong here. Did you check the seating of the RAM? Try running only one RAM chip and in different slots to see if the behavior changes (you could have a damaged chip or slot)
machead3,
0
Score
Avatar
Charlie
25
Answered
PermalinkHistory
Overheating.
As Machead said, a thermal sensor is loose or damaged, or the thermal paste seal between the heat sink and various chips (most likely the processor) has been broken.
A jolt will break the seal between the heatsink and the component it is drawing the heat away from and so will no longer function efficiently, allowing the component to overheat and shutdown to avoid any permanent damage.
The existing thermal paste will need to be removed and reapplied.
Add Your Answer
