Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Questions View all
Adapting Core Duo WiFi card to a Core 2 Duo logic board
MacBook Core Duo A1181 (2.0 GHz)
Hi,
I'd like to replace the mother board of my A1181 Core Duo MacBook, however I didn't find any on the market.
I've seen some full logic board+chassis of Core 2 Duo Macs for sale, which I thought I could use to build a new Mac recovering the screen assembly of my old Mac. However it seems that the WiFi antenna from the Core Duo screen assembly only has 2 wires, while the Core 2 Duo Airport card has connectors for 3 wires.
Could I use the airport card from my Core Duo Mac and put it on the Core 2 Duo logic board? Will it work properly?
Thanks
Aurelien
Update (04/06/2016)
Hi, I have no expectation in particular, I just want to replace my faulty core duo board. The thing is I can only find core 2 duo boards for sale.
Aurelien
Score -1
1 Comment
What is your expectation here? The Core 2 Duo logic board is still limited to OS-X Lion (10.7.5)
by
Add a comment
1 Answer
Most Helpful Answer
The only difference here is the newer Airport card offers Bluetooth services (combo). Your older MacBook has a second board with Bluetooth. So you'll loose Bluetooth services with the newer board as you won't have the needed connections on the new board.
I'm not sure if the logic boards anchor points and other connections will match up. Let us know how it goes. Good Luck
Score 1
1 Comment:
All right, I see. Thanks a lot for you help, Dan.
Aurelien
by
Add a comment
Add your answer
Aurelien Viterisi will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 6
All Time: 98
