Model A1046 or A1095 / 1280x854 screen resolution
118 Questions View all
How can I change the adapter port in my PowerBook G4?
I have a Powerbook G4. The port into which the power adapter fits has gone dead. For a while, I could get it to work by rotating the AC adapter clockwise or counterclockwise. Now it won't supply any power at all to the computer.
Add a comment
Most Helpful Answer
You most likely need to replace the DC-IN port. For getting the right one and the installation instructions please give us the last three letter of your serial number so we can tell which machine you have. It could also be that the AC plug in jacks outer ring has spread and is no longer making secure contact, This can be squeezed tight. Thanks
UPDATE
Now that I have your model number, here's how to do it:
PowerBook G4 Aluminum 15" 1-1.5 GHz DC & Sound Card Replacement
Here's the part: [linked product missing or disabled: IF154-072]
Score 1
2 Comments:
Well, the model number is A1046. Does that help. I can't find a serial number on the outside of the computer. Thanks for your advice...
by
Add a comment
Hi! I have the same problem. Model Nr. is A1138. Could I follow the same instructions? Thanks
Score 1
Add a comment
I need to get to the same spot
Thank you for your support. The Model number on mine is A1104
Add a comment
charger is not working i want new charger please send ansor whare the location charger sale shop now i am abudhabi my number is 00971559900271
1 Comment:
Add a comment
j'ai le même problème que vous merci
Add a comment
Add your answer
Chaz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 3,583
