The first model of the iMac line of personal computers made by Apple. The iMac G3 was produced between 1998 and 2003.
92 Questions View all
Can I run OS 9.2 on an iMac G3 M5521 running 10.2.3
Can I run OS 9.2 on this computer?
I see an ad for an iMac G3 M5521 running 10.2.3
Question... will it run my programs that are written in OS 9.2?
Thanks for your help
Doug
1 Comment
Here's the specs for your system: iMac G3 M5521 Series
by
Add a comment
1 Answer
Chosen Solution
This series of iMac's was the start of OS-X. You could first run a dual boot between OS-9 & OX-X. Later on with the newer OS-X versions for the PowerPC you could run a VM for OS-9 apps within OS-X (Classic Environment).
So simply put yes, you can run OS-9 apps on this system if the system has OS-9 setup.
You are limited here to Panther (10.3.9) as the highest version of OS-X and for OS-9 the last version was 9.2.2. Just remember you are stuck with what you have for apps and you would need a newer version of OS-X to used anything in the Apps store which this system can't support.
I don't recommend using this system on the Internet as Apple has stopped maintaining it so it could be susceptible to trojans and the version of browsers for this release don't support the newer HTML code most sites are using today.
Score 2
Add a comment
Add your answer
Jean Knudson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 171
