2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
265 Questions View all
MacBook Pro wont charge or run on battery
Hello!
After changing the battery of an MacBook Pro 13" retina late 2012 the device will not run on battery power, or charge.
I can supply picture of the motherboard if needed, to see if i may have broken an component.
Score 1
Add a comment
Chosen Solution
sounds likes a faulty battery. not much alternative a part for buying a new battery.
Score 1
1 Comment:
The battery showed as invalid. Thanks for help! After replacing the battery twice i got one that worked.
by
Add a comment
Most Helpful Answer
Download and run Coconut Battery to see the condition of the battery and if it's even being seen. Did you use the guide? What was the source of your replacement?
http://www.coconut-flavour.com/coconutba...
Score 3
Add a comment
Add your answer
[deleted] will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 171
