3
Score
Avatar
David Jonas
100
Asked
Requesting info on how to replace the MBP (A1286) trackpad
History
Mine has been cracked (read: mildly shattered). I've had the bottom case off but I'm hesitant to go any further until I have some more information. I have purchased a new trackpad for it (part no. 661-4948) and am ready to dig in but I would prefer to have a guide of some sort. I'm hoping I don't have to remove the motherboard to do so, but from what I saw in there, it may not be possible.
Anyway, thanks for the support everyone! I'll write-up a guide once I dig in since there doesn't seem to be one.
David
I just completed the swap. The trackpad CAN be removed from the top case. And, what makes it even nicer, is it can be done without removing the motherboard. I got so excited when I realized that it was a very easy thing to do that I forgot to take pictures. However, I'll try to describe how to do it here. All references to left and right are in regard to the computer laying screen down and battery compartment facing you. First, remove the battery, bottom case, and the cross-bar (not sure of the terminology). The bar in question is held in place by 3 black screws on the left and two shorter silver screws on the right. Now you must remove the memory (RAM boards). Not difficult, just grab the gray arms on either side and gently pull them apart. The RAM should pop up. Then just pull it out. The trackpad is held in place by 6 screws (3 on the left and 3 on the right) up top. You can access the set of 3 on the right easily (they were under the memory). The set of 3 on the left are a bit harder....
David Jonas,
They reside under the ribbon cable. It's best to have a small magnetic Phillips head precision screwdriver for this; otherwise you may lose the screw and never get it back. That's never happened to me before.....*ahem* Moving along. Once you get those 6 short screws out, remove the ribbon cable from the connector and slowly pull it out. It is held in place with a small amount of adhesive, so I just worked a pair of tweezers under it. No big deal. Once that's done, work the cable out through the holes it goes through. The top of the trackpad must be tilted out first, then the bottom, as the pad has two tabs at the bottom. Once out, just repeat the process in reverse to get the whole thing back together. I think it took me about 20 minutes total to get the whole thing apart and back together. Very simple. Hopefully this will help someone, as I've heard that a cracked trackpad is a common lament. David
David Jonas,
This is the first time I've heard of this working successfully. Would you give a link to the part?
mayer,
http://cgi.ebay.com/ws/eBayISAPI.dll?Vie... I know it's not all that great a link, but if you click on it soon, it should help you. I think the part number MAY be applicable to the top case part number, but I can't be precisely sure. Honestly, though, it was really easy to do. In fact, my wife is hate-texting me right now about "Dancing With The Stars" right now with it. : -)
David Jonas,
Thanks so much. That's a genuine Apple part 661-4948. It is also the part number for the entire upper case. Very strange.
mayer,
Show 2 more comments
Post Answer
Score
Avatar
mayer
121.8k
Answered
PermalinkHistory
Edited by
Product Image
MacBook Pro 15" Unibody (Late 2008/Early 2009) Upper Case
Case Assembly includes backlit keyboard and trackpad assembly. — 4 available at 299.95 each.
There must be a way, since you can get just the trackpad. It looks like I'm going to have to remove the motherboard though.
David Jonas,
0
Score
Avatar
aerring
Answered
PermalinkHistory
I need to fix this on mine, too. I just won one of these trackpads on eBay and I was wondering if I could get a couple of answers before it gets here.
I read your description on how to do this, and this is what is getting me a little nervous: "remove the ribbon cable from the connector and slowly pull it out. It is held in place with a small amount of adhesive, so I just worked a pair of tweezers under it."
The "connector" you describe...how is it held on there? Does is snap back in place easily?
This is it, right? http://i1177.photobucket.com/albums/x345...
Also, is there any need to remove the triwing screw?
Add Your Answer
