The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
197 Questions View all
How do I install the airport/bluetooth card in a late 2005 model?
Can I install the AirPort Extreme with Bluetooth 2.0+EDR card in my late 2005 power mac G5 myself? Or do I need to take it to Apple? Unless there is so firmware update or reset that has to be done I should be able to do this myself, I hope!
Score -1
Add a comment
Chosen Solution
With due respect to Ralph, I just stuck an airport extreme card in mine and hooked up the connector and had no problems.
Score 1
2 Comments:
Hey I'm glad it worked for you. Does that mean the OP can use the CIP pdf?
by
Sorry, I didn't see your comment till now. Yes the CIP pdf is the way to do it. Really nothing to it.
by
Add a comment
Most Helpful Answer
Here is a link to Apples statement this is not DIY.
http://support.apple.com/kb/HT3096
And here is a link to a pdf version of the service manual. In it you will find setup procedures but no info on installing the card. Good luck. Ralph
http://manuals.info.apple.com/en/Power_M...
Here is the Apple install for card on an early 2005. Check and see if it looks anything like your computer inside.
http://www.info.apple.com/usen/cip/pdf/g...
Score 1
Add a comment
Add your answer
sid sorenson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 7,950
