Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
144 Questions View all
My power cable pin is burnt
hi frnds.... my hard drive is of 250 gb sata .segate.... the power cable pin of the hard drive is burnt(i think due 2 loose connections)....is any where can i fix it and get it into work...or should i buy new one...please answer me frnds....
1 Comment
please check to see if your drive is a SATA or IDE/ATA
by
Add a comment
Most Helpful Answer
If the connections are badly damaged such that cleaning is not possible, then the connector will need to be replaced. Doing that may be a bit tricky without the proper soldering tools, however. Another possibility is to replace the entire drive circuit board with that from an identical model. Like Eric said, also be sure to check and make sure the cable is good, or else you may cause more damage.
Score 1
Add a comment
It is most likely burnt because of a poor connection. Clean the pins/plug, and make sure they make good contact, and the drive maybe it is salvageable.
If you replace the drive, be sure to clean the plug/cable, and that it makes good contact or you may have the same failure again.
Add a comment
Add your answer
pranay raj will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 2,644
