0
Score
Asked
Battery does not charge but power source works
After a tumble from the top of a chair to the floor, MacBook Pro seemed to be okay. However later noticed that the battery was not charging. The power indicator said that it was charging, but the battery charge did not change (or noticeably).
Left plugged in over night the battery went from ~48% to 64% charge. After rebooting the computer the battery will not charge at all. The power connects fine and [so far] everything else seems to functioning properly. I reset the SMC for what it's worth.
The impact was on the corner of the bottom case, the same corner as the right hand rest area. That corner of the case is visually impacted.
Does this sound like an issue of a connection being disrupted or something more serious?
2
Score
rab777hp
12.6k
Answered
First try another charger, or try the charger in another computer, if it works or another charger produces the same results, then this coupled with the visible damage points to needing a new DC-in board. Here's the install guide.
MacBook Pro 15" Unibody (Mid 2009/Mid 2010/Early...
Connects wall adapter power to logic board. — 6 available at 59.95 each.
Just got it back from Apple - they apparently tried replacing the battery, mag-connector, and "battery board" to no avail, suggesting it was damage to the logic board itself. Also realized the keyboard backlighting no longer works. The battery *will* charge but extremely slowly, and so far has peaked out at 75% or so.
Does the laptop work when it is unplugged? Just trying to determine if the battery is connected to the logic board.
Robert Ciaccio,
If it wasn't then it just wouldn't power on.
rab777hp,
