Score
Avatar
Chuck Dyer
13
Asked
Brew head (portafilter) assembly instructions
History
I have a Starbucks Barista espresso maker and I took apart the portafilter (I think it is model 226550650 made by Saeco) to clean it but while doing so the tiny wire spring inside came off. I need assembly instructions in order to put it back together properly.
Edited by: mayer, osvaldo, and oldturkey03 ( )
Post Answer
3
Score
Avatar
Henry H
1.3k
Answered
Accepted Answer
PermalinkHistory
There are two springs inside that portafilter, do you mean the large barrel-shaped one or the smaller, L-shaped one? Here's a picture of the proper spring placement; in that picture the handle of the portafilter would be oriented towards the bottom.
Edited by: Henry H ( )
Henry H, as you seem quite knowledgable, I was wondering if you could take a look at my posted questions and if there is any help you could offer it would be greatly appreciated Here's the link to my question http://www.ifixit.com/Answers/View/40847....
Adam,
Thank you for the pictures.
pati,
I have done the same thing as Chuck (took appart the portafilter to clean it) and looking for help in re-assembly. But the pictures that are referenced to by Henry H detailing where the spring goes does not appear in my browser. Can anyone help?
Dale Simonson,
Hey Dale, I added the picture to my comment so you should be able to see it now.
Henry H,
Thanks Henry, , theats very clear. Now I just have to remember where i put the spring, but with your link I guess i can always buy another.
Dale Simonson,
Score
Avatar
mayer
199.1k
Answered
PermalinkHistory
Please take a look at the teardown to help identify the part you need: Starbucks Barista Teardown
Here's a link to springs for these machines: http://www.cafeparts.com/SearchProducts....
Edited by: mayer ( )
The Barista Teardown does not include the portafilter.
Henry H,
0
Score
Avatar
Steve Munsey
Answered
PermalinkHistory
According to Starbuck's, it is impossible to put one of these back together. They can only be assembled by machine. Once you take it apart, its broke; unless you want a non-pressurized porta-filter.
That was my experience.
I've personally disassembled, cleaned/repaired and re-assembled many of these portafilters, with no ill effects. Starbucks may have sold these machines but they didn't design or manufacturer them, and based on my observations their customer support staff seems to know very little about their proper operation, maintenance or repair.
Henry H,
0
Score
Avatar
rick
Answered
PermalinkHistory
When re-assembling the porta-filter it is important to ensure the male spigot on the grey disc (with the orange seal around it) snaps into the porta-filter valve assembly. You will see on the grey male part there is a recessed area and the valve assembly has a locking tang which snaps in. It is a tight fit but just watch where you put your fingers as to not damage any small springs or moving pieces on the valve assembly. Just my 2 cents...
Edited by: rick ( )
0
Score
Avatar
Richard E Beason
Answered
PermalinkHistory
The second retaining post where the tail of the small spring pushes against is missing on 2 of my 3 portafilters, evidently that is a common failure but no problem, when reassembled, the tail of the spring pushes against the lower housing and still functions as good (actually better) than ever, the value of a good cleaning every once in a while can not be overrated. I have cleaned all my portafilters and they operate better, the pressure build up and release is back to proper operation. I have also disassembled and cleaned one of my pumps which was acting sluggish, just a cleaning and a much improved operations, there is a site which shows you how to disassemble the pump also, just search for it.
0
Score
Avatar
jrizos555
Answered
PermalinkHistory
The post that holds the far side of the L-spring broke off on my portafilter. I had to weld it back in place by heating it with a lighter and holding it there with a pair of tweezers. FYI.
Edited by: jrizos555 ( )
Add Your Answer
Today: 0
This Week: 9
This Month: 42
All Time: 8,236
