Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 Questions View all
How reconnect display date cable?
When reconnecting the display data cable to the logic board on an EMC 2428, is there a trick to lining it up correctly? I assume that the connection is made by inserting the male cable to the female socket on the logic board by sliding it towards the top of the machine (the reverse of the disconnection), yes?. But I cannot get it to seat in the socket. I would hate to damage it.
Score 2
Add a comment
1 Answer
Most Helpful Answer
The only issue one faces is putting the plug in backwards. You may want to take some colored tape to mark across the connector & cable to help remind you which face is outwards.
The alignment is straight in and the wire bail holds the connection.
Score 1
Add a comment
Add your answer
dickson will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 18
All Time: 289
