back of case screw question
i spilled some liquid and had to pop the case to ensure there was no liquid inside. Luckily there wasn't.
I was very careful in taking it off, however, in putting it back i noticed a couple of things:
1. at the front left i am missing a small black plastic thingie (shaped like a basketball key) that exists on the right side. From what i can tell the front case screws (installed through the battery pack cavity on the bottom) goes through this plastic piece. is there anyway to replace this or do i even need to?
2. Of the 12 small screws for the case 2 are just a little shorter. Do these shorter ones go at the back or are they for the front of the case (accessed through battery pack cavity). (For simplicity, I am ignoring the 4 long, 3 ram cover screws and 2 Torx screws which make up the 21 case screws)
3. 1 of the 2 screws for the back of the case does not sit perfectly. I tried both the shorter and longer case screws mention in #2 above. Neither will sit perfectly. I get it in about 90% in to perfect. I took it all apart again and noticed a clear piece of plastic which i tried to insure was not interfering and then put them all back but the problem still exists.
Thanks
Score 1
Add a comment
Chosen Solution
1. It's not missing, there's only the one on the right.
2. Those two go in the battery compartment
3. You must have something blocking it. Use the longer ones.
Score 2
1 Comment:
good answer +
by
Add a comment
thank you
Add a comment
Add your answer
Jim will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 1,240
