Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
wont sync or charge
i phone 3gs 32 gig wont sync or charge after screen being replaced opened it back up all connections solid any one know if jailbreak could cause this or did a part go bad i tried everything
Add a comment
Most Helpful Answer
open it again and check connector no. 4 - it connects the dock with the logic board.
you can use the dock connector guide for that
Score 1
Add a comment
did you try to reset it ?
press and hold the sleep and the home button at the same time until the phone restarts - this could take around 10 seconds.
i know that you wrote that all connections are solid - but number 4 can be *aaaaaarrrrrghhh* - sinc ethe 2 problems are dock related, i would always check number 4 ;-)
Score 1
1 Comment:
Add a comment
Do this: http://support.apple.com/kb/HT1747 (the guide)
and then take a toothbrush and clean the contact on the iPhone.
This helped me!
Add a comment
Add your answer
pat will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 3,286
