Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Questions View all
No Power after CPU upgrade
Hi!
I've updated old iMac cpu from Core Duo to Core 2 Duo.
Now iMac won't power on (power light waking for 5 seconds after it power goes off)
iMac doesn't power even if I tried with original cpu.
Model is iMac Early 2006 20 inch A1174.
Should logic board power on without case (like on desktop)?
Power supply looks OK (I've tried also ATX psu but same problem)
Battery changing tried also.
Some problem on logic board?
HELP!
Score 1
Add a comment
1 Answer
Most Helpful Answer
Examine the capacitors (cans) for corrosion, swelling and or leakage. What are the LEDs in the center showing on boot up? Use the reset and restart gray buttons on the logic board to the left of the LEDs to attempt restart.
Score 1
10 Comments:
This is early 2006 model (no diagnostic leds) :( And capacitors is ok. Before CPU upgrade iMac worked well.
I've tried many cpus but no success. Only power light goes on and hdd starts (no startup chime) 5 seconds after iMac goes off.
by
Please give the last four figures of your serial number, (located on the bottom of the stand).
by
GU2P
EMC No.: 2105
iMac 20"/2.0GHZ/512MB/250GB/SD/AP/BT
by
Apple iMac "Core Duo" 2.0 20-Inch Specs
Identifiers: Early 2006 - MA200LL - iMac4,1 - A1174 - 2105
by
Here's the guide for the CPU upgrade but that does not appear to be your issue. Try disconnecting the hard drive cable and see if it will boot from the original system installation CD. http://www.maclife.com/article/create_up...
by
Show 5 more comments
Add a comment
Add your answer
MacProblemer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 242
