0
Score
Avatar
colleenthompson
1k
Asked
Progressively reluctant to start up; now no chime, just fan.
History
Another carcass from a client. This 2GHz Dual Processor G5 got progressively worse about starting up; sometimes it would come on if the reset button on the logic board was pressed, but now it just whooshes up the fans and won't even chime; the fans stay on, but not loudly. We tried replacing ALL the RAM, using just pairs of RAM in different slots (in case one slot or pair of slots was bad), replacing the PRAM battery, disconnecting the HDs. The client finally gave up and bought a Mac Pro.
Does it sound like the power supply, or the logic board? Any other suggestions before I sell it for parts?
Added later: I did change the PRAM battery, reset NVRAM, zap PRAM, all that stuff. And let it sit with the power unconnected for a number of days.
Edited by
Post Answer
0
Score
Avatar
rj713
33.9k
Answered
PermalinkHistory
Since its a powermac my first thought would be the power supply. Do you have one you can substitute? Ralph
No, I don't. I guess I could buy one to try, and sell it on eBay if it doesn't solve the problem.
colleenthompson,
0
Score
Avatar
Chris Green
14.9k
Answered
PermalinkHistory
if you can manage to get it to boot again, try reseting the NVRAM, boot into open firmware, and type"reset-nvram" (to boot into open firmware, hold "command+option+o+f") also try reseting the PRAM, and checking the PRAM battery, since that little battery can cause so many problems.
Been there, done that. I should have mentioned it. I'll edit the question to reflect that.
colleenthompson,
0
Score
Avatar
Andrew
13
Answered
PermalinkHistory
I seem to be having the same problem as you had, Colleen. Did you have any success with the project or did you just scrap the unit for parts?
The local Mac shop told me that with the G5s, they often suffer expensive logic board and/or power supply failures. I tried everything. It's going to recycling after having spent the last year under my dining room table :)
colleenthompson,
Add Your Answer
