The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
222 Questions View all
Microphone stopped working after screen replacement
Hi,
I replaced my screen on my nexus 5 and now the microphone is not working when making calls! When I click the mic on google now it says unable to open microphone. When I make a call on speaker phone the caller can hear me fine.
Any suggestions would be great.
Thanks,
Jamie
Score 1
Add a comment
Most Helpful Answer
You need to apply some pressure in proper place to mic cable contact.
Check out this video:
https://www.youtube.com/watch?v=P8XpdqOf...
In my case, a thick 2-side tape helped me out with up side not peeled.
Score 2
1 Comment:
with this help of the video this worked for me :)
by
Add a comment
Same problem here. Any solution?
Add a comment
If anyone has this issue again I found a fix. So this happened to me and after taking it apart again a couple of times I noticed the plastic wedges at the top and bottom you remove have a small hole with a channel through. I guess I put one back in upside down blocking the sound to the microphone. Put it back together again and it works like new!
Add a comment
Hi Everyone,
I also face same problem as you all,
recently i get solution for it.
1) Open back cover of nexus5
2) Put some thik paper above battery though the distance between vibrator of back cover and bettery is increase and vibrator not touch to mother board bettery.
these problem may arise because of vibrator touch to the mother board..
I have personally experience to solve it.
Thanks,
Yogesh Patil
Add a comment
Add your answer
Jamie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 2,959
