The Kenmore 90 Series is a washing machine manufactured by Kenmore.
266 Questions View all
Agitates but does not spin
My Kenmore Series 90 direct drive washer sounds like it's spinning, but is not. I checked the motor coupler and it is fine. The clutch seemed fine but I replaced it anyway and it did not fix the problem. The lid switch works OK also. The problem is intermittent, sometimes it spins, sometimes does not. The rest of the cycle works, including agitiation. What else can it be?
Score 2
1 Comment
I have a similar problem but when it gets to the rinse cycle prior to spin the water drains out but you have to physically turn the drum to get it spinning then it spins out okay and throughout the rest of the cycle fine how do I fix that...
by
Add a comment
1 Answer
Chosen Solution
Intermittent problems can be very tough. The first thing that came to mind are "cold solder joints". Here's what they look like: https://www.youtube.com/watch?v=h5_dBMuJ...
Score 1
2 Comments:
Thanks Mayer! However, the clutch replacement fixed the problem. I guess the test that I did immediately after replacing it was not accurate, but now, several loads of laundry later, it is spinning and working great.
by
Glad you got the problem solved ;-)
by
Add a comment
Add your answer
rickmartini64 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 2,903
