Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
299 Questions View all
Question Closed
How do I replace the front pinion bearing on the rear axle?
The front pinion bearing on my truck went out and I can figure out how to get out the old race so I can replace it and the bearing. I'm at a loss considering it's my only vehicle.
Add a comment
Most Helpful Answer
This link tells you how to do it: http://www.ehow.com/how_4674515_replace-...
Score 2
1 Comment:
Useful answer +
by
Add a comment
The original question was about the pinion bearing and the link is for the axle bearings
Add a comment
Is the pinon gear is already out of the truck and are you working on removing the race from the pinion gear or the race in the housing. If its in the pinion gear I usually cut them off carefully with a grinder making sure not to score the shaft as this will cause problems later. if its the housing race you need to come at it from the inside of the differential with a long punch. You should be able to catch the edges of the race from behind looking through the differential from the gear side. If your hesitant about grinding the pinion race of you can use the big red wrench to heat it and tap it off when hot. Hope this helps.
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 8,414
