The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
116 Questions View all
Where does the rubber plug inside of filler door drain to?
1978 mercedes w123 diesel. Inside of fuel door is a rubber plug conical in shape.
does it drain rain water to the outside or does it have another function? threaded plastic weed wacker line to see if i could find the exit area and I did not see it.
Score 1
Add a comment
Chosen Solution
It also covers over filling or expansion of gasoline.
Score 2
Add a comment
Drains to outside below rr fender. If you cannot see your wacker line, the rubber tube may be separated or torn. Push your line as far as you can then reach up inside the fender and feel for it.
Add a comment
Add your answer
mike anthony will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 25
All Time: 433
