Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
204 Questions View all
Will it work?
i have a Mac Mini 2011 2.3 8 GB of RAM with a 500 GB 5400 RPM hard drive. The last digits of my serial number is djdo
I'm just about to order the IFIXIT dual drive kit, I have a SanDisk 120 SSD will it work?
Update
Extreme 120
Score 1
Add a comment
1 Answer
Chosen Solution
There are a few different generations of the SanDisk SSD 120. Do you know which one you have?
Score 1
2 Comments:
SanDisk Extreme SSD compatibility "SanDisk Extreme SSD SATA III 6Gb/s drives are backward compatible with SATA II (3Gb/s) interfaces and SATA I (1.5Gb/s) interfaces. However, speeds will be limited to the lower SATA II or SATA I interface capabilities."
by
You should be fine. Do make sure your firmware is upto date. Follow this Apple T/N: EFI and SMC firmware updates for Intel-based Macs
by
Add a comment
Add your answer
Patrick Westmoreland will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 178
