Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Questions View all
MacBook Screen Goes White
My wife's Macbook, a 2006 Core Duo, has developed a problem where the screen will suddenly go white while she's in the middle of doing something. I am able to remotely look at her screen using Share Screen so I can tell everything is OK apart from her screen. What I normally do is remotely set it to sleep and then sometimes when she wakes it up it gives her the password dialog and often she can continue. Sometimes we have to do this numerous times for it to recover. Is this likely to be the LCD, the inverter or the display data cable. Would probably try the cheapest "fix" first. Thanks.
Add a comment
Most Helpful Answer
Most of time a white screen indicates a hard drive failure. But lets look at the inverter first. Move the screen back and forth and see if you get any changes.
First make sure you have an external backup of her hard drive.
Next hook up your machine to her's using a firewire cable. Start hers up in Target mode by holding down the "T" key . Her hard drive icon should now show up on your desktop. Run Disk Utilities on her machine.
Score 1
3 Comments:
Moving the screen back and fore never makes the screen come back, although I was always suspicious that moving the screen was what made it go white. I have just booted in Target Mode and repaired the disk - it did find corruption (invalid free block count). Ran it for a while after repair and everything was looking good until I went to close the lid and it immediately went white. But again, no amount of wiggling would bring it back.
by
Any suggestions?
by
It's been a while but I thought I should provide the answer. It was the LVDS cable. Replaced it for about £10 - fixed!
by
Add a comment
Add a comment
Add your answer
ploppy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 207
