Score
Danno
219
Asked
External access of MBA HD
I have an HD pulled from a broken up MacBookAir. It uses a special ribbon cable to connect to the LB (?). What can i use to access the data on this drive now that it is out of the laptop. Thanks.
Update
Found the solution here:
http://www.digitalintelligence.com/produ...
If the link doesn't work directly, it's hard to find on the website.
2
Score
Answered
Accepted Answer
1.8" SATA-LIF enclosure:
Score
remacberli
7.3k
Answered
0
Score
rab777hp
12.6k
Answered
0
Score
bac
5.1k
Answered
do you want to permanently use the hard drive as an external drive? if so, then yes as rab777hp said just get a drive enclosure to convert it to an external drive
however, if you only need to temporarily access it externally (e.g. you will later re-install it in some computer), there's a more flexible alternative.
get yourself a Newertech USB 2.0 Universal Drive Adapter, or similar product from another manufacturer. This will let you attach any ATA or SATA drive, 2.5" or 3.5", hard drive or optical drive - via USB to your computer. it's a very handy adapter to have around when you're swapping or cloning drives. But as I say, this is only for temporary use, it's not meant to replace an external drive enclosure.
0
Score
Answered
The MacBook Air that I have contains a Samsung HS12UHE
Which has a SATA interface with a 24 pin LIF connector.
I contacted the support for the Digital Intelligence ZIF Enclosure and not only will this NOT work but they do not have a device that will work with this drive.
If anyone has found an adapter that works with this drive please update this question.
0
Score
Answered
I need an adapter as well.
This one here will not work: http://www.adaptare.de/blog/adapter-fur-...
They tell me in the forum that the MacBook Air is the only computer that uses SATA-ZIF at the moment.
Please let us know if someone finds an adapter for SATA-ZIF.
0
Score
Danno
219
Answered
As i stated way above, the enclosure i bought from Digital Intelligence DID work for me. The LIF connector was actually a "VHIF" connector, but it did work.
Bought this one recently
<http://www.amazon.com/gp/product/B001OYC...>
from Amazon.com and it, too, worked on the model of MacBook Air that i had at the time. It was a LIF connection.
---Danno
"May your Mac(s) always start up!"
I think LB means Logic Board incase anyone was as confused as I was.
Ryan White,
