Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Questions View all
replace 2009 MacBook Pro Logicboard with 2010 Logicboard?
Hi, i have here a Macbook Pro 13-inch from 2009 with a faulty Logicboard, i found a Logicboard of a 2010 13-inch Macbook Pro on Ebay and read somewhere that those two could be used in both cases. Can someone confirm this? That would be super-handy, because then i kind of would have a working AND upgraded Macbook Pro :)
Score 2
1 Comment
no one can help me on this one?
by
Add a comment
Chosen Solution
Jonah, Sorry I just didn't see your question before now.
Generally you can only replace logic boards within the same series. In this case these are the systems within your '09 model: MacBookPro5,5. Here's is the '10 models: MacBookPro7,1.
Often Apple moves things around enough to make it hard to force fit even similar systems. I've not personally tried doing this on this series so I can't say its not possible, just be aware you're a trailblazer here.
Here's the Guides for both review them carefully before you start:
Good Luck!
MacBook Pro 13" Unibody Mid 2009 Logic Board Image
Guide
MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement
Difficulty:
Difficult
40 minutes - 2 hours
MacBook Pro 13" Unibody Mid 2010 Logic Board Image
Guide
MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement
Difficulty:
Moderate
1 - 3 hours
Score 3
5 Comments:
thanks a lot!
by
so there are no problems whatsoever? no problems with mic, webcam cable, or anything? That would be great news indeed!
by
Did you managed to make this change? i have the exact same 2 boards
by
yes i did! it all worked :)
by
How is that working @ Jonah , i might do the same to my mid 2009 Model .
by
Add a comment
My macbook Pro 2010 is out of order for two years due to logic board can it be replaced. please
2 Comments:
Reply please
by
Hi,
Both 2009 and 2010 are compatible, i did the replacement myself.
by
Add a comment
hi pagamim you just change the logic board? my 2009 core 2 duo model can be core i5 is that correct? thank you
1 Comment:
core 2 duo and i5 are 2 different generations, different bus speed, different memory. Not compatible within the macs 2010 and 2009. These two will take only core 2 duo processors
by
Add a comment
Add your answer
jojojonjon will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 16
All Time: 3,839
