Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
154 Questions View all
Not charging my ipad 3
Hi. I've tried changing battery, i've tried changing the dock connection, i've tried different chargers, and different cables. it wont charge. I read something about the coil inside, is this anyting possible to replace and where do i get it? or is it something else?
Add a comment
Chosen Solution
It could be done, depending on what is wrong with it.
You seem determined, seeing that you replaced all those parts so far, but my advice is not to attempt to repair/replace components on the board if this is your first time micro soldering (seems it is from the way you are asking the question).
You can learn to do it, and you can succeed, but during your first attempts you may break more than you fix. And you need specialized tools to work with such small components.
However, for the sake of it, you can start by examining the board using a magnifying glass. Look around where the charging dock connects to the board. Are there missing/broken/damaged components? Let us know if you find something.
Score 1
Add a comment
Seems like there is something wrong with the dc module on the ipad. Im going to try taking it apart today and examining it. Tnx for answer. will get back on you with what i find out. seems like the dc module on the circuit is not so good on the ipad 3.
Add a comment
Add your answer
kimsaetran will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 198
