Originally released on January 22, 2005, the Mac mini is a small form-factor desktop computer made by Apple Inc. Currently, it is one of the four desktop models in the Macintosh lineup, and serves mainly as an alternative to the all-in-one iMac.
872 Questions View all
What is sensor on harddisk? How to re-attach?
When I took out the harddisk (without removing the logic board) I had some struggle until it came out.
When it came along, a cable with some tiny logic board fell down. It looks like some kind of sensor (maybe temperature?) and it looks like it was glued to the harddisk.
Can you confirm that this is a temperature sensor?
How to re-attach it? Just some standard glue?
Score -1
Add a comment
Most Helpful Answer
This is the temperature sensor, and you should reattach it with glue that is conductive (in terms of heat) or electrical tape (you want it to be as close to the HDD as possible as to get the most accurate temp readings.
Score 1
1 Comment:
What type of glue is that? Any idea where to get such a glue? I used ordinary glue and hope that is good enough.
by
Add a comment
Question is: Is temparature sensor show stopper for Hard Drive replacement or not?
1 Comment:
I agree, I mean theres only one fan there. But if your HDD ever goes above 50C you'll never know... (Unless you check the SMART status)
by
Add a comment
I think i found my answer and placed an order from amazon. Looks like sensors can be used with aftermarket HDDs
Check this.
Will try with my 750gb WD which currently sits in my 2009 mini ;)
Add a comment
I scraped the glue off of the old drive and stuck it on the new. It was very pliable, sorta like rubber cement.
There is also one on the SATA connector, but since that stays, it should not be removed.
Make sure you check the thickness on your replacement drive, it is a very tight fit and I don't think any of the thicker high capacity drives will fit.
Add a comment
I just pulled sensor off slowly and glue came with it.
Add a comment
Add your answer
http will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 4,307
