2.26 or 2.4 GHz / White plastic unibody enclosure
645 Questions View all
How can I move the power port back in its place?
Hello,
Yesterday, my laptop fell on the ground and the emplacement where i can normally plug the power cable was pushed a little on the inside of the computer. Since then, when I try to connect the power cable to recharge it, the magnetic tip that normally feeds the device no longer holds properly and i can't charge my laptop anymore. What can i do to fix it ? Should i open the computer myself and put the power port back in its original place?
Thank you very much for your help !
Score -1
Add a comment
1 Answer
Chosen Solution
Study the guide and notes (not just look at them) what you may need to make the repair, and what you may have to do to make the repair can be found here.
Obtain the proper tools, every job is easier when you uses the proper tools.
If this answer is acceptable please remember to return and mark it accepted.
Score 1
1 Comment:
Thank you very much! I will try to repair it!
by
Add a comment
Add your answer
auroreseibert will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 92
