Replaced CD-DVD drive and hard drive at same time
I installed a new hard drive and a new CD-DVD drive at the same time. I need to install OS10.5 and partition my new hard drive but the drive is not recognized. Only my CD-DVD drive shows in disk utility. I double checked my hard drive cable connections. Now what?
Score -1
Add a comment
Chosen Solution
Check the new hard drive for jumpers (if any) and make sure it's set to master. What kind of drive did you get and from where?
Score 1
3 Comments:
I bought a 160 GB PowerBook Hard Drive Hitachi Upgrade from PowerBook Medic they said would work with my iBook G4. My iBook G4 wouldn't recognize the original hard drive anymore and I tried to revive it with Disk Warrior without success. There were no jumpers on the new HD; it was a straight plug in to the cable.
by
+ Ralph
by
Were you booted in target mode to see the optical drive or from the internal PB drive?
by
Add a comment
Jim, your HD ribbon cable may be faulty. Was it replaced too ?
Score 1
4 Comments:
No, I didn't. The reason I didn't is because I used my G4 desktop to read the old harddrive via a fire wire, so I figured the ribbon cable must be ok. I am going to try the firewire thing again to see if my G4 will recognize the iBook G4's new HD. What do you think?
by
That should work.
by
I don't know what you mean by target mode. I had to use my install disk to boot up, then I was suppose to partition my new hard drive in disk utilities but it didn't list my new HD so I could partition it.
by
Could you try to clone your G4 desktop HD to the iBook internal drive via firewire and SuperDuper. The internal drive will be erased and a valid system installed then you'll check if the iBook boot from the internal.
by
Add a comment
Add your answer
Jim Devereaux will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 4
All Time: 1,482
