Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
52 Questions View all
shuts off when tapped in places other than the screen.
I started changing out a broken screen but messed up the antenna in the process. Got them both changed out thanks to IFIXIT. It seems to be ok except for one thing. When you tap the sides or bottom ever so slightly or set it down, it shuts off. After a few seconds, the apple appears like I restarted it or something. The battery was completely drained but is 80% now and still doing it.
Score -1
Add a comment
1 Answer
sounds like the motherboard is not making good contact with the battery underneath. If you open it back up, tighten up the screw holding the board on the battery and that will likely solve.
Add a comment
Add your answer
Tyler will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 717
