Repair information for the first generation Apple iPad available in Wi-Fi and 3G versions with 16, 32, or 64 GB of storage. Released on April 3rd, 2010. Model numbers: A1219 and A1337.
267 Questions View all
Dropped ipad and now sleep button is stuck
Hi all,
I dropped my ipad on floor and now the sleep button is stuck and i can't press it anymore.
The aluminum case has changed shape slightly on the top right part by a few mm. Is it worth trying to open it up and maybe fix the case? If i do open it, is there any chance i can close it up again?
Thanks,
Radu
Score -1
Add a comment
1 Answer
Chosen Solution
it's not an easy task, but you can use the ipad logic board guide.
you can stop after step 8 and try to fix the button.
on the guide page are the needed tools listed - if you use them as shown and if you careful enough, you should be able to close it up again
Score 1
2 Comments:
I did the same thing and have the same problem but don't want to fix it myself. What are my options?
by
Sandy Pennington, you would help your cause tremendously by asking your own question. Yours show up as an answer to a question that is almost a year old. Nobody is going to find your question here, thus nobody can help you. On the right hand side of this page is a link "Ask a question" and if you click on it you get to the site that lets you ask your own. Try it, ts not difficult.
by
Add a comment
Add your answer
pasolradu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 6,183
