steam boiler heats water...has funny smell
The machine heats water and boils the water to steam....the steam has a pungent smell....not sure if it needs to have system cleaned....if so how do you clean it?
When steaming milk it's possible for some of the milk to be drawn up the steam pipe at the end of the process. If enough of the milk gets into the boiler it will cook on the heating element and result in smelly steam. The only way to get rid of it is repeated heat/flush cycles or replace the heating element. To prevent this, every time you steam milk, when you're done remove the pitcher and open the steam knob again for a few seconds. This will clean the wand out.
how do you do that? I have the same problem except it is affecting the taste of the milk as well.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 10
All Time: 1,125
Have you been using tap water or bottled water?
by mayer
I have always used tap water
by Henry Ricciuti
What city and country do you live in?
by mayer
