The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
222 Questions View all
Nexus 5 back cover lose after opening
I opened my nexus 5 to make a repair, but the back cover did not close very well. There are a few points where I suppose the plastic clips were damaged and there is a clear separation between the back cover and the phone. Is there some sort of glue I could use to secure the cover better, but still leave it able to be opened again in the future? Thanks.
Score 2
Add a comment
1 Answer
Either choose double-sided adhesive or replace a new back cover.
3 Comments:
Thanks. Do you have a double-sided adhesive you would recommend for use with phones? I don't think the issue is bad enough to warrant buying a new back cover. It's really only one, maybe two clips that are damaged.
by
Only mentioned that the adhesive used on phone called 3M adhesive like that http://www.witrigs.com/oem-back-supporti... You can pick up and stick it, but the adhesive is a little strong.
by
Thanks for the suggestion. I decided to give this a try. http://www.amazon.com/gp/product/B00BXYW...
by
Add a comment
Add your answer
Chris will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 2,523
